How could I use Appendchunk Function in DBTools
I am a user of Labview2009,I want save a binary file into MySQL(5.1) and I want use the Appendchunk Function ,which is one method of the ADO-parameter object . How should I do it with LabView DBTools?
thanks your help!
charles
(3,533 Views)
Have you tried looking in the Database Connectivity Toolkit documentation yet? I've implemented sending all kinds of data to a SQL database with its help. You can find it at:
https://www.ni.com/docs/en-US/bundle/321525c/resource/321525c.pdf
I'm not aware of how to use the Appendchunk function in LabVIEW. I'm not sure what will be the best way to store your data. You send/receive data with this toolkit using variants, but you might have to tell the database you are sending up a string. So unless you can send up the file, you'll need to open up the file and send its contens up as a string. If I'm wrong about that is there someone that knows how to send up a file to a DB with this toolkit?
Hope that helps!
(3,492 Views)
Correct me if I am wrong
Appendchuck belongs to ADO, which is a microsoft is a set of Component Object Model, so I think it could be implemented using ActiveX method.
(3,462 Views)
