How do I access a reference from a dll in LabVIEW 8
I have written a dll in C++.  Here is the exported function:  extern "C" __declspec(dllexport)void Get_GPS_Error(int Cmd,TIniTable& Output);
How do I access the reference to the initable Output in LabVIEW 8?
Jennifer
(2,584 Views)
A reference is the same as a pointer - it's just a C++ compiler trick to make it look like something else - so you create your binding in LV the same as if it were defined
extern "C" __declspec(dllexport)void Get_GPS_Error(int Cmd,TIniTable* Output);
(2,580 Views)
