How do I add a constant into a DAQMX Graph
Using the example VI "Continious Acquisition Thermocouple Samples Internal Clock" in DAQMX Base how do I add a constant onto the waveform chart that is displaying the thermocouple reading ? What I really want are upper and lower limit constants that are displayed on the graph.
(2,717 Views)
Assuming that you're getting an array of waveform data types back from the DAQ board, you just have to append a couple of waveforms with the same number of samples and a fixed value. I modified an example that uses DAQmx but I think the DAQmx base example should be similar. Change the constants to the upper and lower levels that you want or replace the constants with front panel controls.
(2,710 Views)
