How do I add a process to a project?
I have created a process in the Distributed System Manager, and I have created a large number of variables in that process.  How do I in turn bring that process into a project, perhaps as a library?
(3,123 Views)
Hi Orion,
Thanks for the post.
I haven't got LabVIEW on this machine, but under the DSC palette there is a save process vi. This will create a lvlib for the process. Using the VI Server, you can create a new project reference, then use the add library vi and then create a shared variable to the library. I would recommend taking a look at an example to do with creating libraries programmatically.
I can point you more in the right direction tomorrow, when I am back in the office.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,112 Views)
Thank you.  It's yet another case of, "I know Labview can do it, but how."  Awesome of you to help away from the office even.  Keep up the good work.
(3,097 Views)
