How do I add a shadow in my pictures
Can anybody help me how I can add a shadow in this picture?
Thanks in advance!
(2,999 Views)
Accepted by topic author Chantal
Not sure what you needed exactly, but usually you can do it with blurring/masking combination, something like that:
Here image separated from background, then filtered with Low Pass (7x7), result masked, then filtered again with small kernel for antialiasing, then simply added with original image. You can use attached VI as starting point (IMAQ Vision required).
Andrey.
(2,970 Views)
Thanks! I think I can do something with this 🙂
(2,966 Views)
