How do I add an icon to my executable?
I've tried using the editor, i've tried using a free .ico from web... it doesn't matter. In the end, the .exe will look as below, in the attached capture.
Message 21 of 31
(1,476 Views)
This is an example of an Icon I built with IconEdit2 -- it is for a test routine we called "Cinnamon" (I just pasted the .ico file on my blue desktop).  This happens to be a 256 x 256 pixel icon (to make the image pretty).
Bob Schor
Message 22 of 31
(1,455 Views)
Which version of LabVIEW are you using?
Please post your .ico file.
George Zou
Message 23 of 31
(1,449 Views)
It looks cool. Did you have any issues seeing the icon in the finished executable?
Message 24 of 31
(1,441 Views)
I'm using LabVIEW 2020.
"Icon" is the one downloaded from the web which worked so far up to the moment i've written to this topic.
"TeMaCoN_Icon" is the one developed in labview icon editor.
Is there anything else i should check in any other submenu ?
None of them are working right now.
Message 25 of 31
(1,433 Views)
I find LabVIEW frustrating inconsistent with icons. Sometimes I have found that the first icon you try is the only one that works, for evermore. Sometimes the icon doesn't appear at all. I don't have any insight into what's causing this. Some people don't appear to have any issues, which in itself might be a clue. Perhaps the root cause is something else.
Message 26 of 31
(1,424 Views)
It seems LabVIEW remembers the old icon.
Even "Clean" the build doesn't work.
I have to create a new build script to update the icon.
George Zou
Message 27 of 31
(1,411 Views)
George,
     Your post reminded me of a problem I haven't thought about in years!  Particularly when creating icons, sometimes things go awry, and updates for the Icons don't seem to work.  Turns out that Windows has an "Icon Cache", so if you edit an Icon, you might have a lovely Icon, but it won't be "attached" to your executable because Windows says "Oh, I already have an Icon for that, I'll just use the one in the Cache".
     Do a Web search for "Windows Icon Cache", and you'll find where "IconCache.db" is hidden in your Profile.  Follow the instructions to delete it and see if that fixes the problem.  [It does entail a trivial delay when you reboot and Windows rebuilds the cache, but you will probably not notice it ...].
Bob Schor
Message 28 of 31
(1,391 Views)
iconcache_48.db and iconcache_32.db haven't modified for ~3 years.
So iconcache is likely not the problem.
George Zou
Message 29 of 31
(1,385 Views)
I would not make that assumption with MS OS.
Former Certified LabVIEW Developer (CLD)
Message 30 of 31
(1,352 Views)
