How do I aquire signals from two National Instruments PCI-6034E boards (one for thermocouples and one for 10V signals), from a single VI?
I'm using LabVIEW 6.0 with two PCI-6034E multifunction DAQ boards (from National Instruments). Each board is connected to an SCB-68 terminal block. I need to develop a VI that aquires signals from both boards; displays the measurements; and also writes the data to a file. One sample per second would be fast enough for my current application. Are any example VI's available that come close to this?
(2,445 Views)
You'll probably not be able to use a single VI for this. You'll have to acquire the signals separately from both boards, and then display them and save them to a file. I can develop one for you rather easily, but I'll have to know a few specs. Contact me at mark.wysong@ae.ge.com, and I'll get you going quickly.
Mark
(2,445 Views)
