How do I archive datasets programatically with citadel?
Is there a way to archive datasets created by a dataset marking server programatically with Labview?  I can do it with MAX, but when I use the Archive Traces.vi in labview, it only archives the individual traces and does not keep the datasets in tact.  Is there a way to call out the datasets in the URL's that you feed the Archive Traces.vi?  Other than that, I can see no way to specify datasets to archive.
Craig
(2,974 Views)
Hi Craig,
I have a document for you to take a look at. https://www.ni.com/en/support/documentation/supplemental/12/logging-data-with-national-instruments-c...
It describes archiving data about midway through the page. Take a look at this and if this still isn't quite what you are looking for, please let me know.
Best Regards,
Travis Ann
Customer Education Product Marketing Manager
(2,959 Views)
Hi, Travis,
Thanks for the reply.  Yes, I've read through that document a bunch, and it has been helpful.  I am able to archive all my TRACES with MAX and programatically as they describe in the document, but I when I do it programatically, the corresponding DATASET information does not get archived to the new database.  After archiving programatically, I can go to the new database with MAX and see the traces, but no datasets.  Whereas when I Archive using MAX, you can see the DATASETS in the new database when it gets finished.  By the way, I'm using Labview 8.2.1.  Not sure what version my DSC module is, but it should be the latest one that works with LV8.2.1.
Let me know if you come up with anything.
Craig
(2,957 Views)
Hi Craig,
Are you getting any error code or error message at all? Also, it might be helpful if you post screenshots of where you should be seeing the datasets and you aren't. Also, can you verify what version DSC module you have?
Travis Ann
(2,937 Views)
