How do I automate a Thorlabs TDC001 controller so that it moves a specified distance at trigger times using labview?
I am trying to automate a Thorlabs TDC001 controller using Labview.  I can control the motor from the ActiveX GUI on the front panel, but when I try to automate it it just moves at random intervals in whatever direction.  How can I automate the controller to move specified distances at particular time intervals?
Thanks!
(4,651 Views)
Are you using NI Motion software to interface with the motor controller?
(4,604 Views)
The manual http://www.thorlabs.com/thorcat/15700/TDC001-Manual.pdf has a full list of methods and properties (see Appendix D) which can be set using ActiveX (software must be installed).  This is how you would control it via LabVIEW; unless of course they can provide you will LabVIEW drivers.
(4,599 Views)
I am using LabView and the ActiveX GUI on the front panel.  I've attached my code thus far.  I have been able to automate the controller, but I cannot input the amount it moves and the time interval for the movement.
Thanks!
(4,593 Views)
SetVelParams allows you to set the velocity parameters (i don't have the code installed so I'm sorry I can't give more specific advice).
You have a few options for movement.
MoveAbsolute (move to position X from the zero point )
MoveAbosluteEX  (move to position X from zero point in terms of programmed units)
MoveRelative (move set number of steps from current position)
MoveRelativeEX (move set number of programmed units from current position)
(4,586 Views)
I tried different combinations of those, but the code won't run.  Can you be more specific?
Thanks!
(4,570 Views)
There does not seem to be anything obvious in the LabVIEW code that would cause the problem.  It sounds like there is a problem in what is being sent to the driver.  You should probably double check the inputs to the driver function in the manual.
(4,531 Views)
