How do I build a standalone application which does not need a runtime engine using linux version 6i?
You will always need either Labview installed or the runtime engine installed. Or if the question is how to run without Labview installed, you should be able to run a VI with just the runtime engine on the machine. Of course, you will not be able to modify the program on the machine.
(2,628 Views)
