How do I build a two-dimensional point-by-point histogram?
I'm trying to write a VI that will update an intensity chart point-by-point given a set of input data of form `array of cluster of two elements'; the NI VI GeneralHistogramPtByPt.vi is fine for the one-dimensional case, but I want a generalization.
Some stipulations:
No shift registers (static variables)
Routine must accept data samples on unknown length
(2,743 Views)
I am not sure I understand your requirements completely. Do you need to generate a new histogram of the circular buffer everytime there is a new sample? If this is the case you can use the point-bypoint queue to store the values and calculate the histogram on that data.
I am attaching a couple of examples here. One of them generates a running histogram based on what I mantioned before and the second one applies a running histogram over a waveform.
Please let me know if you have any further questions.
Juan Carlos
N.I.
(2,743 Views)
