How do I calculate areas under the curves above and below the x axis at 0?
The xy graph generated is similar to a sinusoidal representing the magnetic intensity of the poles of a motor. For each of the four areas above and below the x axis at 0 I would like to calculate the area then do a variance analysis on the 8 areas. Can anyone suggest a method to calculate each of the 8 areas. See the attached vi to understand better what I'm trying to do.
Thank you.
(5,805 Views)
I cannot open the vi because I have LV2010, However you can check the link below
https://decibel.ni.com/content/docs/DOC-13010
Hope this helps
(5,793 Views)
Thank you for the example, but I'd like to do it programmatically for each area without the user having to move the cursors since it is part of an automated process.
(5,781 Views)
Could you post your code in LV2010, I cannot open it since I have LV2010
(5,779 Views)
there is not much in the VI to look at.
For numerical analysis, it might be sufficient to do the "numerical integral" - just add the numbers, each multiplied with your Delta-x. To determine the areas in your special case, just look check if < or > 0.0
It might not be the best solution, but for this amount of datapoints it will work well enough.
Maybe this quick and dirty solution might help you out already (;
(5,777 Views)
Hi all,
If you are simply looking to do numeric integration, there is built in functionality to do that.  The help file is here:
http://zone.ni.com/reference/en-XX/help/371361H-01/gmath/numeric_integration/
You will may have to do some edge checking if you want to break this down into individual components.
Let us know if you need any more assistance
(5,762 Views)
