How do I call LabVIEW's ActiveX interface from .NET?
I'm trying to call a LabVIEW VI from C# using LabVIEW's ActiveX interface. I've successfully imported LabVIEW.tlb and can do a few simple things like load a VI into memory and run it.
But things get more complicated when I need to use a cluster output from one VI as the input to another. The return value of GetControlValue is, unfortunately, a System.Object refnum. This is useless for passing into LabVIEW: it's just a pointer.
How to I get C# to pass the System.Object refnum in as a Variant containing the actual cluster data instead of a Variant containing a 32-bit pointer? I'd even settle for flattening the C# object to some kind of string, but the ToString() method is useless: it returns "System.Object[]" ins
tead of an actual representation of the data.
(3,269 Views)
Hello -
I'm not familiar with C# commands, but I can point you to some useful information on LabVIEW and ActiveX:
You can obtain a description of all the methods and properties in the LabVIEW help. In LabVIEW 7.0 you should open help (Help >> VI, Function, & How-To Help). From the contents tab select Windows Connectivity >> ActiveX >> Properties & Methods. Here you will find information on the properties and methods that LabVIEW makes available.
This tutorial is a great introduction to LabVIEW and ActiveX.
I've also attached an example (written in LabWindows/CVI) which demonstrates how to use the LabVIEW ActiveX Automation interface to la
unch and run a LabVIEW VI. In this application the LabWindows/CVI example acts as the Automation Client to control LabVIEW through LabVIEW's Automation Server.
Good luck with your project and have a great day!
Becky B.
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
(3,269 Views)
