How do I call a method from a .NET assembly created with LabVIEW 2009 where method parameter list includes enum?
I built a .NET assembly from a LabVIEW 2009 project and I want to call some methods in this assembly from a C# .NET application I am writing.  The LabVIEW vi contains two enum controls defined as First_Enum, values = VAL_1, VAL_2, VAL_3, VAL_4, VAL_5; and  Second_Enum, values = VAL_2-1, VAL_2-2, VAL_2-3.
When I set up the build for the .NET assembly it defines a prototype like the following:
                                          void assemblyName(ED1 paramName1, ED2 paramName2)
where I presume ED1 and ED2 represent the enums defined on the FP.
In the C# application I add the newly created assembly and add a reference to it in my project explorer.  When I attempt to call the method assemblyName(), I am not able to select any of the defined values of the enums.  I have attempted to define a variable of type ED1, e.g, but when I do this there are no options for values.
Can someone help me with this?  I have tried everything I can think of, both regarding different options when building the .NET assembly in LabVIEW and referencing these values in my C# code.
(3,936 Views)
Hi protocol_alpha,
I created a .NET assembly that included enums.  However, when I build the assembly, it defines my enums as UINT 16.   This makes sense because an enum passes an integer.  I'm not sure why you are getting a definition of ED1 or ED2.  Could you post your code so that I can try to replicate what you're seeing?
Best Regards
Starla T.
(3,916 Views)
We see probably the same error with LV2010 here.
It appears to be a bug in LabView that if the class contains
a. an enum declared as an ulong
b. at least 1 method that either takes in the enum as a parameter and/or return the enum.
c. If you have this in the enum in hex format, like "ALL = 0xFFFFFFFFFFFFFFFF"
Then LabView would silently fail to reflect the elements in the class.
For some reason, if you instead declare it as "ALL = 18446744073709551615", then LabView works.
Can somebody verify this behavior and post some feedback, please?
(3,801 Views)
Missed one thing:
The problem is that LabVIEW doesn't show any .NET class methods.
protocol_alpha (the originator of this thread) couldn't select any enum values.
But in my case all the methods are invisible in LabVIEW.
(3,798 Views)
I'm having the exact same issue using VS2017/VS2019 and LabView 2015-32Bit/LabView 2017-64Bit.
Some help on this issue would be helpful, thanks.
(2,496 Views)
