How do I change a 2D time variant to a 2D string?
Hi, I am new to LabVIEW.  Can someone help me with this question?
Please see attached.
mrgudwrnch
(3,049 Views)
Accepted by topic author mrgudwrnch
You have neither variants nor a 2D array. What you have coming out of the loop is a 1D array of timestamps. To convert a timestamp into a string you can use the Format Into String function or the Format Date/Time String. The Write to Spreadsheet File function has a 1D array input so you can use that instead of the 2D input.
(3,044 Views)
(3,015 Views)
Thanks for your help.  Is this the best way to do this?
(3,003 Views)
That would do it. You can change the output string by editing the format string. The LabVIEW documentation provides the details on the various formatting options and codes.
Tip: The sequence frame in your case is not necessary. You only need to use sequence frames when dataflow does not allow you to explicitly set an execution order.
(2,998 Views)
