How do I change my fft display resolution
I'm sampling at 6000 hz but when I display my fft it only has a resolution of 1hz. How can I increase this resolution?
(3,089 Views)
FFT resolution depends on the number of samples as well as the sampling rate. More samples => better resolution. Check the help files. I think they have some discussion of the resolution. Also any textbook on Fourier analysis will give the theory (not for the mathematically faint-hearted).
Lynn
(3,089 Views)
Try using the FFT Zoom. I also came across this problem recently. I increased the resolution by using the fft zoom to meet my needs.
(3,089 Views)
The following links should help in the theory of FFT and applying it in LabVIEW.
Making Frequency Domain Measurements
An Overview of Frequency-Domain Measurements
Matt F
(3,089 Views)
