How do I change page label on tab control
Is there a way to change a page label in tab control at run-time?
(4,599 Views)
Create a property node from your tab control. From this, select the Pages property. This will output an array which contains references to all of your pages. To access a specific page, index this array accordingly. Note, this must be done using the index array function, "auto-indexing" as an input to a for-loop (for example) does not work for some reason. Once you have indexed the array, create another property node and select PageLabel and set this to writeable. Hope this helps!
(4,593 Views)
Hello Festo,
As far as I know this property is read only at run time as you can see in the LabVIEW help window attached.
Paulo
(4,592 Views)
Sorry, Made a mistake. Use the TabCaption property of the page instead of the PageLabel. I have attached an example for you in version 7.0.
-EF
(4,583 Views)
