How do I change the Printpage settings
Dear all..
 As I have an print screen image of an Front panel with graph. So I am trying to save it in jpg format and trying to print this using a command mspaint.exe "File Path" /p from the system exec function available in labview. after the print the screen is splitted into two pages. With half each. so is there any way to get the print of my front panel with plots in the graph. moreover a complete image print at the output. pls guide me.
(2,798 Views)
I would request you to go through the given below link. It should help you solve the issue.
http://forums.ni.com/t5/LabVIEW/snapshot-button/m-p/734468/highlight/true#M336274
Sagar G Yadav
Application Engineer | National Instruments
(2,779 Views)
Dear YADAV..
 Thanks for the suggestion... i am able to get the screen shot but the way if i use above said tecnic will give me the screen shot withought graph. but i need the print screen with complete FP with grapgh so i could get complete FP in the single page as print out.
Regards
Bhargav..
(2,774 Views)
Hi Bhargav,
Of course you can do that. Just set the 'Visible Area Only' Boolean property of the specific invoke node to FALSE.
Hope it should work for you, else feel free to revert back.
Sagar G Yadav
(2,770 Views)
Hi Anyways i have got another alternative solution .... Cheers, Bhargav..
(2,767 Views)
Dear all/ I am trying to read the System Settings and Espeacially Tagnames form a configured  yokogawa MW100 through labview drivers can u please help me getting the tagnames and even the System settings configured from MW100
(2,738 Views)
