How do I change the color of a string contol when using a vi reference to that control
I know that I can change the bg color of the string control by simply creating a property node and using the text/bg color. But... I need to open a vi reference and find my control due to the number of controls used in my app. I can't seem access the text/bg color when doing this. SEE EXAMPLE VI.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,914 Views)
Hello BJD,
The control reference you are using is a general one, and therefore you need to typecast the control reference to a more specific class. To do this use the function "To More Specific Class" that can be found in the application control palette. This will expose all the properties of a specific type of control. See the attached vi.
Regards
Gerardo Garcia
(2,914 Views)
Thank you. That works great.
BJD1613
Philips Respironics
(2,914 Views)
