How do I change the colours oints plotted on graph?
I have played around with all the properties of 3D graphs, yet there are still a few I cannot figure out.
1) How do I change the colours of the plotted points? size of points?
2) How do I make the axes constant? (so that max and min don't change at all)
I am using LabVIEW 7.0.
Thanks!
IBAHKA
Message 1 of 11
(3,611 Views)
You didn't dig long enough :
CWGraph3D>properties... then :
1/ Plots> Style> Points to display the points
2/ Point where you get the style and size of the points to display. I would be pleased to figure out what frequency is.
For the axes, see the answer to your previous post !
CC
Chilly Charly    (aka CC)
Message 2 of 11
(3,601 Views)
Chilly,
I can't find style? what is it? I can find Plots on the drop menu of properties, but where does style come from?
A little lost...
Message 3 of 11
(3,598 Views)
Chilly,
I hope you don't think that I'm being lazy. I've been working on this for 4 hours. I still can't change the colours and sizes of data points plotted.
I am attaching my 3D graphing program. I would really appreciate of you could look at it! Thank you and sorry for being such a nuisance!
IBAHKA
Message 4 of 11
(3,596 Views)
Here is a screen shot of what you should get, using rightClick on the control, then Properties.
May be you have been searching in the property nodes, instead of going directly to the control functions ?
Hope this helps
CC
Message 5 of 11
(3,586 Views)
I have never been able to open anything like that? Can you open myy program and see if you can do this? Perhaps we have different versions of LabVIEW?
Message 6 of 11
(3,574 Views)
Just to add to what Chilly Charly already pointed out, it appears that you are searching for "plots" on the property node. What you need to do instead is go to the front panel, right-click on the 3D graph control, click on CWGraph3D and finally click on Properties. You would find the plots properties here.
Also I was able to reproduce the above in the VI you posted.
Ankita A.
Message 7 of 11
(3,560 Views)
Looks like at least one seed geminated.
Ben
Message 8 of 11
(3,559 Views)
Found it! Thanks for everyone's help!
IBAHKA
Message 9 of 11
(3,548 Views)
Just when I think I have it!...
I am able to open the property and apply teh colours, however, as soon as I run the program, the colours all change back to lime green!?! (I go to CWGraph3D>Properties...>Plots> Style,Point - change colours and apply it... but still no luck.) I also di d some work on teh block diagram, but no luck again. I feel like there is a simple solution in my code, but I don't know what it is.
I'd appreciate if you could look at it once more and actually run teh code to see if you have the same problem.
Thanks, IBAHKA
Message 10 of 11
(3,542 Views)
