How do I change the contrast of Picture using LabVIEW7.1 PDS
Hi
Can anyone help me out for the following querry. I am using LabVIEW7.1 PDS
How do I change the contrast of Picture at runtime ?
Ashutosh
(3,242 Views)
Ashutosh C
What is PDS?  There are many ways to change the contrast.  If you have IMAQ Vision there are many tools available for changing contrast.  A picture is nothing more than an array of numbers so you could modify the actual pixel values.  For this I would use .BMP format because it is an uncompressed image.  As a last resort you could look into calling a Microsoft or other image processing product using an ActiveX control.  Give me some more information and I can make a specific suggestion.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,238 Views)
Thanks Matt,
PDS - Professional Development System
Presently I do not have IMAQ Vision, The other option as you mentioned could be helpful to me.
Can you suggest / guide me for calling a Microsoft or other image processing product using an ActiveX control.
Wolud be thankful for reply.
Ashutosh C
(3,233 Views)
Try this VI for adjusting contrast.  Just click on the color to get the right color to overlay to fix the image.
Matt
Matthew Fitzsimons
(3,226 Views)
Thanks Matt,
The vi you send was very helpful to me.
Thank u once again
Regards
Ashutosh CSmiley Happy
(3,202 Views)
Ashutosh
If you like the VI please give the post a good rating.
Matt
Matthew Fitzsimons
(3,189 Views)
