How do I change the default properties of a graph
I have a favorite visual style for my front panel graphs (and controls), and I am tired of changing color, fonts, size each time manually. Is there a way I can change the default properties of a graph object, so that when I put it on the front panel, it already has the desired look?
Thank you in advance
(2,676 Views)
Did you try creating a "XControl" ? for the graph or other controls
Regards
Guru (CLA)
(2,671 Views)
Create customized controls for your graphs and controls and setup your favorite attributes .
Use your custom controls instead of the canned controls.
Do a search on UI and you will find a community that already created custom controls.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(2,656 Views)
