How do I change the library folder that I already created?
For example, I have created a folder called [test] under [userlib] and used several libraries on [test].
Now that you have changed the location of the [test] folder, and edited the [palette set] using [palette editor], but the icons appear strange.
I wonder how to change the folder of the library that is already in use.
Do I need to edit all [dir.mnu] file?
Message 1 of 1
(2,031 Views)
