How do I clear a string entry at the end of a measurement?
I am using the string entry as input from a barcode scanner which is reading Alpha-numeric serial numbers. The string is compared to to verify the serial number is correct. This output starts a subvi that is performing the measurement.
(2,877 Views)
What is your question? Please be more detailed.
(2,877 Views)
I have a string constant as a control that the operator will use via a keyboard wedge barcode scanner to read a serial number from the UIT. This string is then compared using a string subset which will produe a true(displays S/N as UIT) or false (incorrect S/N). The true output also is used to start a subVi which is performing flow and pressure measurements. At the completion (Pass Only)of the flow/pressure test, I would like the the string contant display to clear. Thanx for your help!
(2,877 Views)
Guessing now.
How about using a local to write an empty string to the indicator just before you do the read from the barcode scanner?
Is this what you need?
Else, please elaborate.
Ben
(2,876 Views)
Ben,
This morning I added a better explanation (I hope) of how I have structured my vi. It may help you understand what I am trying to achieve or it may change your comment. I will try your suggestion. thanx.
(2,876 Views)
