How do I clear graph before running?
I waould like to clear graph before each run. I have read the help desks and conferred with the example, but have not be successful in creating a way to clear the graph before each run. Any help would be appreciated. Attached is a graphing program I created. I did not include the SubVIs, but believe process can still be understood. Thanks so much for your help.
(3,547 Views)
There are several ways to do this, two possibilities are show in the attached image (pick only one!)
Method 1: wire an empty cluster to a local variable of the graph
(Simply create a local variable, right-click ...create Constant. Make sure it executes before your main program, e.g. by using a sequence as shown)
Method 2: If the graph is empty by default, just create an invoke node and initialize it to defaults.
(3,539 Views)
The above instructions show how to programmatically clear the graph as a first step whenever the program is run.
If you want to clear the graph manually before actually running the program, simply right-click on the graph and select:
"Data Operations ... Clear graph" 🙂
(3,536 Views)
