How do I combine numerous global variable VIs into a single one?
I am editing some existing Labview code, and creating new global variables. Each time I get another global VI. How do I combine them into a single global VI?
Steve
(3,492 Views)
If you have that many global variables you should probably look at whether you can rewrite your code in a way that minimizes them.
That said, a global variable VI is just a VI with controls on the front panel and no block diagram.  You can add as many controls as you want to that front panel and each one will become a global variable.  You can either open the global VI directly, or double-click on any global variable terminal to open the associated VI.
(3,486 Views)
Thank you for the response. I had tried this and have tried again. I have set up a very simple VI with a global variable. I add a control into the global front panel, but can get no further. Nothing apperas in the main block diagram, nothinbg I click on helps, the manuals don't talk about it. I am clearly missing somthing, any clues would be gratefully received.
Steve
(3,466 Views)
To insert your global variable into your block diagram, add it to your block diagram in the same way you would add any other subVI.  You can right-click in the block diagram and choose "Select a VI" to choose your global VI, which will place a global terminal.  You can also open the global VI and drag the icon from the upper-right corner of the front panel into your block diagram.  Left click on the global's terminal to select the appropriate variable.
(3,456 Views)
Many thanks, that's now sorted.
Steve
(3,428 Views)
