01-20-2010 12:46 PM
01-20-2010 12:54 PM - edited 01-20-2010 12:55 PM
01-20-2010 01:00 PM
01-20-2010 01:15 PM
Well, if you can't get it to work with Hyperterminal, you won't be able to get it to work with LabVIEW. Assuming that all of your checks have been done correctly and that you have also enabled the instrument for RS-232 (from the front panel) it would appear to be a hardware problem with the instrument or the com port of your pc. Checking the pc is easy with a loopback (connect pin 2 to pin 3). After that, it's time to contact Fluke.
01-20-2010 01:17 PM
