How do I communicate with 3 Ethernet devices
I am new to using ethernet and I need help writting a LabVIEW vi to communicate with 3 Omega devices. I need to open a connection to all 3 at the same time and read data from each. I am able to communicate with them individually using the TCP/IP vis (see attached vi) but I don't know how to communicate with all 3 at the same time.
Can anyone help?
Bert
(2,670 Views)
Hello Bert
You can simply replicate your code (copy and paste) so as to open multiple TCP/IP sessions to all three instruments as the same time. Make sure that you specify different IP addresses though.
Chetan K
AE-NIC
(2,648 Views)
I tried that but I get an error code 63.
(2,643 Views)
Sorry, I get error code 62.
Bert
(2,639 Views)
