07-14-2009 01:27 PM
I connected my thermocouple to a reference junction (http://www.omega.com/Temperature/pdf/LXCJ.pdf), which I then connected to the DAQ board. How do I configure the DAQ assistant settings to reflect this? I'm not sure if I should be using built-in, CJC constant, or channel; none of those seem to apply to the way I've connected the reference junction. Unfortunately omega did not provide a manual so I am unsure of whether I have connected the reference junction correctly.
In the CJC case, the output values are oscillating all over. Any suggestions?
07-15-2009 06:22 PM
The DAQ Assitant should have an option to sleect a channel as your CJC, just make sure you wire your device to the correct channel.
Glenn
07-16-2009 01:52 PM
Actually when I try to select channel, it wants a 'virtual' channel, not a 'physical' channel.
Also, the reference junction was designed to connect directly to the thermocouple, so it cannot sit on its own channel separate from the thermocouple...
07-17-2009 05:08 PM
If the Refernce junction was designed as an extension of the thermocouple, try selecting built in.
