How do I connect input wires to a vi which is to be opened in a subpanel?
I am trying to connect input wires to a subVi which I want to open inside the subPanel of the main vi frontpanel. It does not seem to work so far...I can't find the right tool. Is there any way how I can do this?
(2,975 Views)
Hi
You can do it, but not the "usual" way. You have to use VI server to open a reference to the SubVI and then use methods like "Set Control Value" or "Set Control Value [Variant]".
Hope it help
PJM
vipm.io | jki.net
(2,975 Views)
Would it be possible for you to provide a short sample block diagram including the VIs?
TC
(2,975 Views)
Here you go.
PJM
vipm.io | jki.net
(2,975 Views)
Thank you so much. It is exactly what I needed.
TC
(2,975 Views)
