How do I connect loose ends on a skeletonized mesh network?
I am attempting to use Labview to represent a mesh network of the actin cytoskeleton in an endothelial cell in order to characterize the average fiber length and pore size.  I use a thresholded binary image which is skeletonized (skeleton M) to show the network.  The network shows up fine but there are many loose ends (points which should be connected but are not).  In order to quantify pore sizes and fiber lengths, I need these loose ends to connect with their most likely neighboring fiber.  Is there any way Labview can do this (preferably automated)?  Thanks
-Nate
(2,615 Views)
I've been wondering about this also....I’ve been wanting to do the same for awhile now.
I think a combination hardware/software solution would be best. With Labview being the software, I think what you're looking for is an instrument that not only provides inverse reactive current for use in unilateral phase detractors but can also be capable of automatically synchronizing cardinal gram meters. Several years ago, I knew of the existence of such an instrument. It was called the Retro Encabulator. It was very unique in that instead of power being generated by the relative motion of conductors and fluxes, it was produced by the modial interaction of magneto reluctance and capacitive duractance. I think the device had a base-plate of pre-fabulated amulite, surmounted by a malleable logarithmic casing in such a way that the two spurving bearings were in a direct line with the panametric fan. A last-minute design change added six hydrocoptic marzel-vanes, fitted to the ambifasciant lunar wane shaft to prevent side fumbling.  They're usually hard to find since many are reserved replacement parts for Lotus-O-Deltoid type machines. (They usually are placed in panendermic semi-boloid slots in the stator, every seventh conductor being connected by a non-reversible tremie pipe to the differential girdle spring). If your skeletonized mesh network requires fluorescent score motion, you may also need to simulate a drawn reciprocation dingle arm, to reduce sinusoidal depleneration.
For an example of the labview code to interface with this device, search the forums for "milford-trenions".
Hope this clears thing up!
--Chief
(2,594 Views)
