How do I connect the pins of my PCI 6221 to make a 4 wire resistance measurement?
I would like to use my PCI 6221 card to make a  four wire resistance measure ( with labview 8.0 & XP ). I don't seem to be able to find any clear infomation on how to connect the pin's to the resistance I want to measure. Would anybody know how to do this with a PCI 6221 card?
The only thing I have found is this link but it's not detailed engouh :
By the way, does the PCI generate its own courrent for the measurment or does it just read it ( so the current needs to be generated externaly) ?  I hope I am clear enough   🙂
Thanks for your,
Marc
(3,172 Views)
The 6221 just generates and reads voltages- not currents.
You will have to make your own current source and sensing front end- not a trivial task. You have not supplied any specs- what range of resistances you need to measure, resolution, accuracy, throughput.
I would advise instead of trying to make a 4 wire ohms instrument that you purchase an off-the-shelf DMM with such capability and control it via GPIB or serial port.
NI does make a 6 1/2 digit DMM card that is PCI based and does 4 wire ohms measurement- search the porduct manuals on NI 4070.
Good Luck
(3,155 Views)
Hi AnalogKid2DigitalMan,
Thanks for your answer. Actually, I was looking into what could the PCI 6221 card do because I haven't succeeded in making my HP 34401A run faster than 1 sample per 400 ms, which is too slow...I would need to take at least one 4 wire measurement every 100 ms. I have tried all of the 5 examples of the Labview library...
Marc
(3,148 Views)
Are you measuring the same component every 100msec or are you switching components in and out every 100msec?
(3,147 Views)
I am measuring the same component : It's  the resistance of a surface of a thin layer that changes value according to a heater under it. It is heated for 14 ms every second and I would like the follow the value of the resistance every 100 ms as the surface cools down...to see the effect of the heater on the resistance value.
Marc
(3,137 Views)
What's the expected range of the resistance of the thin film?
(3,134 Views)
I think you have the wrong tools...
In this case I would go for a stabalized current source, and measure the voltage drop over the layer. Make sure you don't have any ground loops
Ton
My LabVIEW Ideas
(3,122 Views)
