How do I control the column names when using
(3,212 Views)
Hi Fred,
Would you mind reposting the question?  Be sure to only include a short summary in the title, and the main question in the body of the post.
Cheers,
Matt Pollock
(3,182 Views)
Columns with names could mean you are talking about a table or a multicolumn listbox, for example.
To set the column headers, use a property nodes and wire a 1D array of strings to the "Column Header Strings[]" property.
If you meant something else, please repeat the question with a bit more detail. 😉
Message Edited by altenbach on 01-02-2007 09:13 AM
(3,166 Views)
