How do I control the location where a "dialog button" appears?
I have multiple loops running simultaneously and in each of them I have "dialog buttons". In some cases the "dialog buttons" appear over-lapping. Is there anyway that I can control the location where a "dialog button" appears on the monitor?
Chuck M.
Message 1 of 8
(3,367 Views)
What is a "dialog button"?  Can you give a screen shot of what you mean?
Message 2 of 8
(3,363 Views)
Sorry, "Dialog" Function.
Message 3 of 8
(3,361 Views)
Look under "Rotate" in the case statement. I have this VI running in several loops simultaneously.
Message 4 of 8
(3,360 Views)
Accepted by topic author chuck72352
You create your own subVI that behaves like a dialog box.  That way you can control its appearance and location.  Look in the Example Finder for Dialog Box Demo to get started.
Message 5 of 8
(3,339 Views)
I only see one loop. Do you have other VIs running simultaneously? Or is this VI called by several higher-level VIs simultaneously?
I also don't understand why you have metronomes inside the case structures. Are you trying to create wait statements? If so, use the Wait function, not the metronome. Why does the "De-Rotate" case have two metronomes?
Message 6 of 8
(3,336 Views)
I can't open your vi because I don't have LabVIEW 8.6, but if you're asking about a "One Button Dialog" function, you can found some hints in the Community (thanks to jschwartz)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 7 of 8
(3,321 Views)
Thank you for the help.     (Yes I have other loops similar to this one running in parallel)
Message 8 of 8
(3,296 Views)
