How do I convert a Visual Basic Variant containing a string and a boolean to a Labview data type
Use the "Get Variant Attribute" function (Functions>>Advanced>>Data Maniputlation>>Variant). Make sure that you wire a string or boolean to the default value input to define the data type of the output, when you are getting the values of your string and boolean, respectively.
-Jim
(2,979 Views)
