How do I convert a string of binary numbers into a Digital/Analog waveform?
Let's say I have a string "0001" that I want to covert into a digital waveform.  What is the best way to do it?
Stefano
(3,121 Views)
Use Boolean Array to Digital.  You will have to convert the text 0101 to boolean F T F T.  You can do this with simple case statement.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,096 Views)
Try the "DWDT Spreadsheet String to Digital.VI" and set the delimeter to nothing.
(3,085 Views)
