How do I coordinate x-y motorized stages and AI Read to occur at same time?
I am trying to scan an object and measure its reflectance. The return light is sent to an analog input and taken in by AI Read. The object is being moved under a scanner by two Melles Griot stepper stage and run by pre-made programs. The two functions aer placed in parallel. However, it appears that my program moves the stage and then collects data from AI Read. I want AI to be collecting data WHILE the stages are moving.
(2,579 Views)
Have you considered using triggered analog input acquisition -- you can set the trigger so that data collection starts when the stage moves. Can you attach a piece of code so that readers can check it out -- do you have the analog code running in a seperate While loop?
RamziH.
(2,579 Views)
