How do I correct a build error while saving "Calculate Color Index Array.vi"?
I have an application that takes some data and then periodically generates a nifty 3d graph.  When trying to compile this application to run on a stand-alone machine, i get an error message that crashes the build.  This is the information that is generated for the error:
An error occurred while saving the following file:
C:\National Instruments\LabVIEW 2009\vi.lib\Math Plots\3D Math Plots\3D Surface\3D Surface Datatype\Protected\Create Plot Data\Calculate Color Index Array.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
Details:
Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Item_OnDoProperties.vi -> AB_Item_OnDoProperties.vi.ProxyCaller
Can anyone help me understand why the 3D Surface Datatype.lvclass keeps booching on my compile?
Thanks!
(2,914 Views)
