How do I correct an error saving an 8.6 RT application for 8.5?
The error is:  Missing Object.  The object "Bitpack to Array" does not exist in the previous version.
                      Missing Object.  The object "Unbitpack from Array" does not exist in the previous version.
(2,876 Views)
Do you mean that you are trying to save an 8.6 file in 8.5 format?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,874 Views)
Where did you get the vis "bitpack to array" and "unbitpack from array". I could not find them in 8.6.
Claire Reid
(2,847 Views)
I couldn't resolve the references with "find", including vi.lib, objects or text, or in the vi hierarchy.  Is there a more comprehensive search?
(2,839 Views)
Hi Cprog,
I am assuming you are trying to save an application from 8.6 to 8.5. Those VIs are not in 8.5. Are you able to post you code.
Claire Reid
(2,836 Views)
