How do I create .NET assembly dll in Microsoft Visual Studio 2008?
I want to make a DLL using .NET assembly so I can import in to Labview by right clicking in the block diagram pane -> connectivity -> .NET -> Constructor Node.
Which project should I create?   I worked in a DLL output type of Win32 Console Application.  I guess it does not use .NET Assembly because when I call the dll I created to the labview, it tells me "This is not a .NET assembly"
Can someone help me here? Thank you
(5,763 Views)
I don't know if it's called something different in VS 2008, but in 2005 it's called a "Class Library". A Console Application is an executable application.
(5,760 Views)
