How do I create a struct in LV?
I am trying to create the equivalent of a struct within LV.  I believe using a cluster is the route to go but I don't have much experience with them.  I would like to define and initialize a group of variables and then reference them by name further along in the code.  Any suggestions?
Thank you,
Stephen
(3,984 Views)
Oh man.... another text programmer Smiley Mad
I'm just kidding.
You can bundle the 'variables' into a cluster.
Then you can reference the cluster later in the code, and unbundle it to access the various parts.
Message Edited by Cory K on 06-05-2009 11:39 AM
Cory K
(3,981 Views)
char message[5]={'T','h','a','n','k','s'};
for (i; i <=5; i++)
    Write(message[i]);
Just kidding.  Thanks for that, I was trying to get this to work yesterday but it kept unbundling with only one name (the first variable placed in the cluster box). It was happening because I needed to name the rest of the variables before unbundling the cluster.
(3,974 Views)
When you use the 'unbundle' function, it should automatically resize itself to display all of the components.
Cory K
(3,958 Views)
either resize the "unbundle by name" function to show more/all cluster elements or use the simple "unbundle" function which always shows all elements (but not by name).Or click the element name in the "unbundle by name" function to select a different element...
And please try to use LabView names (cluster instead of "struct", cluster element instead of "variable") as it will be a lot easier to understand your question and to provide help Smiley Wink
Message Edited by GerdW on 06-05-2009 08:12 PM
(3,951 Views)
STRUCT => CLUSTER;
it is usually best to make your clusters as typdefs and use bundle/unbundle by name
which is like
struct.field = value    this is bundle by name.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,949 Views)
