How do I create an enum typedef?
I want to create an enum typedef?  I should be able to right click on the enum and select "Advanced" from the drop-down menu.  However, when I do that, "Advanced" is greyed-out.  What should I do?
Thanks in advance.
Message 1 of 14
(16,925 Views)
Select the control then click "Customize Control..." in the Edit menu.
Jim
Message 2 of 14
(16,913 Views)
jcarmody wrote:
1) Select the control then click "Customize Control..." in the Edit menu.
Prequil to Jim's reply...
-1 ) Right-click on the enum constant and select "Change to Control"
0) Switch to the front panel
Continue with Jim's instruction.
Explanation: The "customize" option is not available for non-type def'd enum constants on the diagram.
Ben
PS: Jim, I like your poem.
Message 3 of 14
(16,885 Views)
The instructions given worked for me.  Thanks so much!
However, this brings up another related question.  When I open the Standard State Machine template, there's a Beginning State typedef and a Next State typedef.  When I double click on either, nothing shows up on the front panel.  Can you explain what's different?
Message 4 of 14
(16,860 Views)
They are constants on your block diagram. They have no representation on the front panel.
You can right-click them as well and select 'Open Type Def' or 'Advanced -> Customize'.
Felix
Message 5 of 14
(16,848 Views)
This was the nature of my original question in this tread.  When I create a constant enum, I can't make a typdef out of it because the menu items that would normally be used are greyed out.
Message 6 of 14
(16,837 Views)
Joe,
It is simple theory.
You can have 'N' no. of constant instances for a Typedef Enum variable; but not 'N' no. of variable instances for a Enum constant. Thats why, the menu items are normally greyed out for an Enum constant.
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 14
(16,790 Views)
I'm sorry, I still don't get it.  Can you explain the steps I would have to go thru to duplicate the Beginning State or Next State typdefs from the Standard State Machine template?
Message 8 of 14
(16,768 Views)
Joe,
See Ben's reply. It has already got the answer you want...
Message 9 of 14
(16,766 Views)
I realize this thread is old, but for anyone else like myself who comes acorss this in the future, I believe Ben missed a step at the end to create a type def like the ones used for a state machine.
Once the custom control front panel is opened after selecting customize controls, select whether you want a type def or a strict type def from the drop down menu at the top.
When you then go to your block diagram and switch the control to a constant, you can right-click on it and see the option to open type def.
Refer to this link for clarification: https://www.ni.com/docs/en-US/bundle/labview/page/creating-type-definitions-and-strict-type-definiti...
Chris
Message 10 of 14
(15,317 Views)
