How do I create and adjust a timescale of a scope display?
I am wondering how I can change (real-time), the X-axis scale of a scope display? Right now, it has the starting data point number on the left and the ending one on the right. I *can* click on those to either expand or compress the data display, but usually the data is going by too fast to do this. Also, since I know the sample rate, I'd rather create a control that sets some property of the graph, but I can't figure out which property.
Any ideas?
Jason
(2,578 Views)
You can use the property node and link that to the waveform graph. Then, you can set different parameters that define the range for X.
Prakash K
(2,566 Views)
