How do I customize X-axis on XY Graph?
Hi Guys,
I want to customize x-axis as 1, 3, 10, 100, 200.
This screenshot is set by XScale.MarkerVals[], but the display isn't meet my requirement.
This x-axis  is what I want, how to do it?
(3,695 Views)
Accepted by topic author QH_Dai
Looks close to a log scale, so by using a log scale and arbitary markers you can get this (here manually rigth click in the xy graph, x-scale ... , but you can use the property nodes to set them in the program
If you really need a 'arbitary' spacing , apply a custom scale transformation and use text-markers to label them.
Something inbetween, use two xy graphs, one log one lin, set the range, make the border transparent and stick them together ....  avoiding the transformation.....
Greetings from Germany
Henrik
LV since v3.1
(3,655 Views)
I see, log scale is what I want, tks.
(3,632 Views)
