How do I customize the TestStand menu in a LabVIEW operator interface
I manage the sequence files that the application uses to test a part.  I would like to remove several of the default (TestStand) menu items from the File (TS__FILE) and the Configure (TS__Configure) MENUS.  Where do I adjust those menus?
-Kenneth
(2,631 Views)
Hi Kenneth,
The menu bars in the LabVIEW OI are built during runtime in "Rebuild Menu Bar.vi" that is located in the Case 3 of the only case statement in the top level VI.
Here you can decide what commands are available to the user from the menu bar by limiting which commands are inserted.
Check out this forum post for more detailed information on how you would go about this process.
LabVIEW version of TestStand OI
Hope this helps Kenneth. Have a good one.
Dan Weiland
(2,621 Views)
