How do I deactivate the right mouse button in LabVIEW?
I have a VI which needs to be safe to use and a friend came to test it - all was well apart from when the VI was running, he hit the right mouse button and a menu appeared over buttons - I would prefer this VI not to do this. How can I de-activate the right mouse button on running VI's??? This occures in both versions 5 and 6.
(3,060 Views)
DeeJay,
This is probably best answered by some Windows/VC++/VB people. This is a system question. What you need to find out is what dll to call, and what function to call within that dll. I have, somewhere, a function that reads the mouse position (it's also on this site somewhere) and I am sure that the same dll (win32.dll???) is the one to call, but I don't know the function to call or how to set the function to disable the mouse.
Search for a Visual Basic users group, or just search MSDN for your question. If you find the answer, be sure to share it with us here.
Thanks, and good luck
(3,060 Views)
In LV 6 goto VI Properties>>Window Appearance>>Custimize and uncheck the "Allow Run-Time Pop-up Menu" option. This won't allow the menu to appear on controls when they are right-clicked at run-time. You can do the same thing LV 5 but I don't remember exactly how the menu system is laid out.
Hope this is what you meant.
Brian
(3,060 Views)
Okay, now I know what you meant.
Goto VI properties, and de select allow runtime popup menu.
Done
(3,060 Views)
