I have a system here which is sort of a finite state machine, using digital I/O, I am monitoring a series of digital inputs which in turn form a binary number which is the input to a case structure. Depending on the binary string (number) that is read by the case structure, a particular series of boolean constants (T or F) exit through the case structure which are then used as my digital outputs (in my case they are controlling a series of relays). Basically, I have a condition where I would like one of the relays to be time delayed when switching in one direction, but not in the other. The problem is that when I do delay this bit, it also delays all of the bits coming from the case structure.
i.e. all the relays are delayed. How can I delay just one of them?
