How do I determine array size in a formula node
I am feeding an array into a formula node to perform an operation on. However the size of the array can be an arbitrary size. How can I determine its size to use for iterating through a for loop?
I suppose that I could add another input that is fed with the array size from the array palate but I would like to know if it can be done inside the formula node itself.
(5,481 Views)
Your own advice is the only and best one.
greetings from the Netherlands
(5,463 Views)
Sometimes I scare myself. Smiley Surprised
(5,449 Views)
Inside formula node you can use following code to find the array size.
variable=sizeOfDim(array_variable,0);
eg: n=sizeOfDim(a,0);
Rocky
(4,785 Views)
