How do I determine if excel is loaded on a machine using LabVIEW.
using the included support, if Excel is not installed then the VI wont run. I want a way to determine at runtime if Excel is available, and if so give the user the option to log Excel style, if not then the option is not available.
(2,632 Views)
If you attempt to do an Automation Open on the Excel Application, you'll get an error. Another way is to read the registry.
(2,632 Views)
