How do I determine which control in a cluster fired the <All elements> value change event?
Hello all
I have a cluster (control) which looks like this:
This is a single channel of data, consisting of a gauge with two needles (set point and actual), a separate numeric control linked to the gauge (fixed point data type), three combo boxes and a button. When the user interacts with any of  these items I generate a Modbus packet to retrieve / set the data. My current implementation uses events, one for every single control in the channel - and I have 5 channels. Is there a way of using the <All elements> setting in the event handler and then using the source node (or similar) to determine which control was actually clicked? I might then be able to use an array of clusters to simplify further. I am struggling to understand the source node.
Thanks for any help
Ray
(5,792 Views)
Accepted by topic author Radiator
Jim
(4,223 Views)
As Jim showed, your best bet is to just do a comparison between "New Value" and "Old Value" and search for a FALSE.
The Source just tells you what caused the event to fire.  This gives you a distinction between ActiveX events, User Events, and actions the user performed on the GUI.
(4,211 Views)
Thanks to you both, I'm glad it was simple.
(4,200 Views)
